Hi Mickmate,
Thanks for the reply.
The flange does rotate straight. The nose of the pinion points 4 degrees up and 3.8 degrees to the passenger side.
I did check the frame for overall square and plumb a while back, but did not check to see if the IRS sub-frame is square to the main frame.
That's next I guess.
I removed the back bracket from the Diff and can rotate and lift the unit to square. I am considering fabbing up a new rear bracket, as long as the axle positions check out.
Regards,
Evan
