Old 10-10-2001, 06:19 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Sorry Tom,
Junkyards are South of DC on MD Rt. 5 & 301 around Waldorf. One in VA on Rt. 1 just North of Woodbridge.
I used V belts, not serpentine. Set w/ everything except PS was around $250 or so (Summit). PS was xtra $50, or so.
Be careful with the bracketry. Just because it fits the F150 or 250, doesn't necessarily mean it'll fit a Cobra. Hood, front suspension, steering shaft, headers, PS hoses are all a tight fit, with a 351. Worse with a 460. You might could use pieces of factory brackets, then have to make some. I used factory pump bracket from a van, but had to fab the rest. Mock it all up and check clearances.
What are you using for a steering rack, PS pump, hoses, alternator?
