other problem
Jim,
You have something else wrong, check for binding as the drive gear goes into the ring gear.Also replace both battery cables with new # 1 cables, with the ground going directly to engine, you could have a high resistance connection and straining the starter if it does not have enough amperage.
Good Luck,
Perry.
