Thread: engine run on
Old 08-24-2008, 05:26 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by Excaliber View Post
Dieseling is really bad for your motor, whatever you do, STOP IT from happening, NOW.
Dieseling can damage the motor. Many cars in the old days (~65 to ~85) had a anti-dieseling solenoid. It was an electric device that acted as a throttle stop. When energized, it positioned the throttle at its proper place, but when the key was turned off, the throttle was allowed to close even more to eliminate the run-on. Try higher octane gas and make sure your initial timing is correct. If that does not cure the problem, its time to search thru some junk yards for the solenoid and bracket from a car with your motor.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Just anther thought to add to the list.
Warren
