There is always the "leaning brick" method.
You get a board that you can get to lean against the brake pedal. You put three or four spikes in it to hold your average brick ( or anything else with good weight ). Attach the brick to the board and then lean the board against the pedal.
Open the bleeder. Wait. Close the bleeder. Pull board back. Lean Board again.
Repeat until you get steady fluid.
