Thread: Front sway bar
Old 08-25-2008, 02:58 AM
Double Venom's Avatar
Double Venom Double Venom is offline
JAC,
I have never been able to confirm who makes the front sway bar. The CR's bar is almost an inch thick and is definately to strong for the car. Even for a BB motor. If you have the skills get a SPEEDWAY MOTORS" CATALOG, go with one somewhere around a 1/2 to 5/8's thick, buy two eyelets for the ends, bend the bar, easy to do, weld the ends on and it will bolt right up to the CR attaching brackets, or they can be bought seperate too.
Professional hours on the track testing the OEM front sway bar by a very professional driver, (Drove the Indy 500 for years) and the ultimate decision was to simply unhook it.
Probably not what you wanted to hear but there it is. Either leave the OEM off or built one for the car.
If you really want to be good, and easier to make make your own rear one too that is fully adjustable and this one is pretty easy to make. The rear one done right will have a multituude of adjustiong slots and the rods will have heims for setting tension. A little practice and you an really dial both of them in. When our driver got done with both bars his skid pad test was dam near a full 2G's!
DV
Just a little testing and in the scheme of things, not much money!
