Cobra Mike I have 2 shelby blocks, CSX58 and CSX428. I got my Shelby blocks before Ponds and Genesis where maken them. We know the story with the Dove motors.
![Hmmm](images/smilies/erm.gif)
There are Shelby blocks maken over 2,000 HP at this time. The ponds block is the correct look for a cobra. Safe power it handles will be in the 800hp range. Very few of us are looking for this much power. Except for the oiling differents between the 2 and no date code on the shelby block, I would still take the shebly for the $1,000.00 more price tag. Here's why. The heads are held in place with studs that pull from the mains of the block not the cylinder walls. This stops any out of round of the cylinders and lose of compression over a long time of running. 4 bolts, 2 per side and to main studs hold the middle 3 caps in place. There is no cap walking in this block. Unless you are turning 7,500 rpms or higher the side oiler system IMO doesn't matter if you have a good machinist clean out all the
oil galleys. Limiters to the heads of in the .070" - .090" orifaces to controll and keep more
oil in the bottom end. A HVHP
oil pump for good pressure, ( 70-85 psi hot ) at 2,500 rpms. A peroiler IMO a must to add to the car. The only down side I found on a Shelby block is the helicoils they use, I have removed all the helicoils in my block and gone to timeserts. I like to have a steel to steel material. For racing IMO this is better than helicoils in aluminium. I don't have a lot of info on the ponds blocks, KCR and Gessford Machine would be the ones to talk to. Which ever motor you go with, remember that it is ONLY going to run as well as the parts are matched to all work in the same rpm range and the machinist has good eyes and takes PRIDE in his work.
![Smilie](images/smilies/smile.gif)
The power for your motor is in the intake,heads, exhaust and putting the right cam in the motor. You may want to go with Ponds and buy the best set of heads from KCR for the price different saved between blocks. Also look at his hydro roller cam shafts. Build a torque motor and don't get catch up in the HP game. If you are racing go HP. A 482-527 FE is alot of motor. Limit the rpms to 6,200 for a big stroker and you will have many years of great power and durability.
![Too Cool](images/smilies/icon6.gif)
Rick L
