Rwillia4,
Yes, there is some adjustability in there, the 3 holes are elongated, and it appeared to come that way from the factory. I have not had my car re-aligned yet, but it has always tracked pretty well as it came from the factory.
What would the purpose of the backing plate be? The actual mount, which is bolted on to this tab, has three studs in it... they are only just long enough, so that might be an issue.
If I can see you, I'm too close
