Old 08-26-2008, 11:05 AM
Juggernaut's Avatar
Juggernaut Juggernaut is offline
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Bob, one more vote for an air pocket.
I drilled a small hole in my thermostat & installed it with the hole at the 12 o'clock position. Left the cap off, filled up the system, started the engine, when the thermostat opened & the coolant level dropped, I topped off the system, filled the overflow tank up about 1/3 & shut everything down. Started it again & let it run a few more minutes, saw the coolant in the overflow bubble a little & knew any remaining air was coming out.
No problems at all!
Randy
Juggernaut
