Old 08-28-2008, 04:48 AM
Mac VABCH's Avatar
Mac VABCH Mac VABCH is offline
Cobra Make, Engine: BDR #250
Olddog,
I have the same motor and MassFlo system in my car. Except that I have 24lb injectors. It has been tuned on a dyno making 338 HP with a very flat torque curve at 12.4 A/F. I am the original owner, a few months ago I droke the Mass air meter and needed a replacement. My engine alway stumbled when cold but cleared up very quickly, Then ran beautifully. With the new meter I have had a few glitches. I had to buy the "new" Frequency to Voltage converter with the new meter. Check the elements of the meter as mine had some gunk on it, be very carful as the filament are very fragile. I had MassFlo clean mine and check the meter for proper size. I agree to run in open loop... I think that you may injector to big for you motor, As my motor run very good with 24lb injectors. Mac
