427sharpe,
I know this is asking a lot:
do you have the part numbers for the alternator brackets and the two pulleys (water pump and alt)? What are the diameters for the three pulleys? Does it cool and charge OK?
I suppose the crank pulley is single groove. I believe I'll need a double groove crank pulley so I can drive the PS pump off the second groove.
Might you have a photo of the setup you could share?
Black powdercoat on a $100 set of pulleys and brackets would look just dandy to me!
Regards,
Tom
