I had the same problem with a Ford Racing water inlet housing. The leak was at the bypass hose connection. Ford did not machine the threads so they seal when tightened. It appears the leak is at the gasket, but it you have a heater hose it may be coming from the screwed in bypass hose fitting.
Dave Stewart
Double Oak, TX
