Old 08-30-2008, 11:31 AM
Mac VABCH's Avatar
Mac VABCH Mac VABCH is offline
Cobra Make, Engine: BDR #250
Peter,
What type clutch actuation do you have, is it a slave cylinder or hydraulic throw out bearing. If you don't know is it a new car that you had built and if so what manufacture. You have most likely had your first slave cylinder failure. Most replica have this as a problem not really limited to one brand or the other. I can be fixed one of two ways. Replace the slave and mounting set up or switch to a hydraulic t/o bearing. The second route is the way I went but others have replaced the slave and mount. Vintage Motorsports has a good slave and mount system and mount that they have had good success with...Mac
