Ed
the 160... is the last series of the correct number instead of what I sent you the first time. Sorry if I got confusing. Lets try this one more time:
FR20160AD IS the correct complete number.
You will have to ask them if a large Plastic shaped dish is needed with this column/wheel and that we do not have the "nut" that normally holds a steering wheel on? (I doubt if this wheel uses that type of nut but without seeing the adapter, the mentioned number, I don't know including a heavy gauge spring that is normally used, may not be used with this wheel.
I hope that I have made this somewhat understandable this time!
DV
