Old 08-31-2008, 04:40 AM
Default Try G-Force or Transzillia for the swap
jjl Try either of the 2 above for the swapping of the position on the shifter. If not try and goggle it. someone would have the change setup. I know 1 change is with an external shifter arm that hooks to the orginial spot and has the shifter mount forward. You would need room in the tunnel for this swap. You will have to watch the driveshaft angles. Rick
