Old 09-01-2008, 04:45 PM
csx wnab's Avatar
csx wnab csx wnab is offline
Cobra Make, Engine: superformance/427 fe ford
Default bearing shifting in carrier
went to mini nats...............tracked car............experianced some binding in right rear. and upon closer inspection found that the outer bearing had shifted to the inside of carrier housing. (probably in the left handers, under lateral load). and in doing so the inner rotor face is now making contact with the inner caliper housing, thus createing a metal to metal contact. also the five studs holding the spinner adaptor.............. the heads of these studs are also contacting the hub assembly. anyone experiance this same condition? any ideas?
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
