You should have the steering rack centered with wheels straight so as to have equal steering radius (left and right) for each wheel. If one wheel steers sharper than the other you may have a rub. You must also have the wheel/spring compressed to correctly check for alignment (and rubs). Just make sure you do all these basic adjustments. ERA has built close to a thousand Cobras without these tire issues.
