Street, correct! And you should have no probs with a mechanical TOB. Next possible concern, it may be difficult to get the input shaft of the tranny to slip all the way through the clutch plate hub. All depends on how well you centered it over the pilot bushing. Even if you assembled the clutch with an alignment tool, sometimes the plastic tool will still let the clutch plate sag a little. So if you have a problem getting it to go the last inch .. look at that.
Sam
