Old 09-05-2008, 02:08 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Originally Posted by BlackSnake View Post
If you have to remove it use dental floss back and forth, like some one mentioned earlier
...thin nylon fishing line works well also
I used 3M Emblem Adhesive #08061 clear, tried the tape but the emblems stuck up to much because of the thickness of the tape(the thin stuff). I removed the pins from the back and filed them flat then applied a coating of the adhesive brushed it out with a small hobby brush, let it tack up some then applied the emblems...you can move the emblems slightly right after installation if you do't get them just right. Stayed on the car for over 5 years
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
