It is not the o-ring. It is where the silver part crimps to the black cable. Easy fix take some RTV and smear it around the crimp to seal between the crimp and cable. I used a hot glue gun because I was in a hurry and so far so good. If you remove the cable from the transmission let it hang for awhile so all the fluid can drip out of it then put the rtv, like I said i was in a hurry so i removed and used a hot glue gun since it dries immediately.
