Any Holley Guru’s? 800 CFM Four Barrel Street/Strip Carburetor double pumper. Casting says 4780-4 3395 metering block 11398
I bought a used carb off ebay. I took it apart to rebuild it .. new gaskets Hp fast kit rebuild kit. Once I took it apart I discovered there is no power valve.
The casting on the metering block is block off. I've tried researching it and no information. How is this going to run? All I can guess is it more of a strip/ carb. I think the carb was modified with different metering blocks? Any thoughts. I plane on using it on a stroked 393 with performer manifold, aluminum heads (2.02 intakes), street/strip cam.
