KCM,
First off the actual frame mounts are welded to your frame already. This will locate the motor where it they needs to be, second hopefully your kit came with the engine mounts that bolt directly to the motor and the bolt on frame mounts, Large "V" type bracket with a elongated hole for the correct motor mounts that bolt to the frame brackets.. From this point (Since I don't have the numbers accessible to me, make one more contact, "cpt eddie- (on the forum daily) and ask for his part numbers for the urethane mounts. You want the ones with a large "pin" that will fit iinto the frame brackets. You do not want the "horsehoe" type motor mounts. The transmission mount and the motor mounts will come as a set. If your trying to find the origiinal motor mounts listed in the original CR's manual-don't. They are no longer available and do not apply! Sorry I don't have the numbers for you but Ed will and your motor mounting/location problems are over.
Hope this makes sense to you.
DV
PS If you weren't aware of it and you probably are the Lone Star is a Duplicate of the CR's with minor mods to it. Should be a fairly easy swap out.
