Old 09-10-2008, 02:55 PM
Double Venom's Avatar
Double Venom Double Venom is offline
KCM,
I hope you're still around. The motor mounts I use are polyurethane (Red, you can get black) part # ENE-4.1122R. If you buy these buy the kit and it will include the tranny mount then all you will need is the "V" shaped frame mount (which should come with the kit) to match it all up. You can find the mounts in Jegs or Summit. (Energy Suspension)
DV
