Thread: New Trans
Old 09-10-2008, 02:41 PM
blykins blykins is offline
Having an overdrive is awesome. The torque capacity of the TKO 600 will give you a little peace of mind as well.
What are you currently using for a bellhousing?
If you're using a stock or Lakewood bellhousing, you'll either need to order the trans with a short input shaft, or you can use a spacer. A spacer is not a good way to go in my eyes, but others use them.
You can also upgrade to a Quicktime bellhousing. They only weigh 20 lbs and they don't require a spacer or a short input.
You will also need a new clutch disc with 26 splines.
On October 1st, I understand that Tremec will be raising their prices, and the TKO 600's will go up about $200.
I'm running a special on TKO's and Quicktime bellhousings right now. Tremec dictates a minimum advertised price, but if you need a price, then shoot me a PM or email and I'll treat you right. I give good discounts for Club Cobra members.
If your Toploader is a big in/big out, then you should be able to sell it very easily and recoup some of the TKO cost.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
