If you can see the splines on the end of your transmission shaft then no. There is a rubber gromet that seals your driveshaft input shaft on the end of your transmission! Your driveshaft should fit over the exposed splines of the output shaft and inside the rubber gromet.
I have seen in some cases a hard plastic plug installed on the end of the transmission output shaft of the transmission that keeps the transmission fluid from leaking out during the install.
Sammy, I hope I didn't steal your thunder!
Clois
"Let's roll"
"Be part of Something Good
