Thread: Transmissions
Old 10-13-2001, 07:49 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The T56 is a wide ratio 4 spd with a double overdrive. The first 4 gears are similar to a wide ratio toploader, with the 5th and 6th being roughly .75 and .5 depending upon which T56 application. I checked into this 2 or so years ago, and at that time no one made any adapter, so it would have to be custom made. I spoke with D&D Transmissions, and they knew alot about what it would take, I think another 2-3K$. Get a Super Ford mag, and look in there for their advertisement to contact them.
If you want an "overdrive" capability, then you can use a wide ratio toploader with a 3.07 or 3.23 rear, or if you want a ratio spread similar to a close ratio toploader, then get a Richmond 5 spd with a 2.88 or so rear, or get a 5 spd Jerico or G-Force and get custom ratio's to your liking.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
