09-13-2008, 04:34 PM
CT
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Tunnel installation ?
I'm starting to get the interior stuff going and did my first dry fit of the tunnel. I did read the manual and the description is brief. I've noticed a couple things.
1. The engine is off set to the left to balance the car.
2. The transmission follows the engine so that the transmission does not seem the line up exactly in the middle of the tunnel.
I measured across the x member brace on the frame the the trans is definitely not in the middle.
I put some grease on top of the tunnel to get my starting point to where the shift lever comes up.
I quickly noticed that the center of the shifter is off from the center of the tunnel. If I cut out the hole for the shifter cover it will be off center of the tunnel. Is this normal?
