Old 09-15-2008, 05:48 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
aluminum block is in
about the end of 1st page and start of second are two clutch choices, if i was to do it again i would go with mac vbach's recommended setup. with either of these clutches you can use a lightweight aluminum bellhousing, i wouldn't recommend either of these clutch setups or bellhousing if you are doing drag strip time.
