Old 09-16-2008, 12:24 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you are planning to add air conditioning to your MKIII, you will want to be sure to NOT pull the power for that air conditioning system thru the cars main wiring harness.
Bypassing the main harness, AMP meter and such is easy to do. Just be sure to fuse the power supply line properly...
SPFWiringDiagrams@Comcast.net
