KCMCHRIS
I don't know if this will help or if it is what you are looking for. About 2 years after I built my "92 CR, I switched from a 351W to a FE427. I have the following parts from the 351 engine mountings. The CR weldments and motor mounts (1 pc-D7ZA-6038 AA and 1pc-D7ZA-6B032 A1A). These are the ones that I used for the 351 and they worked. I also have the headers and side pipes (both were ceramic coated). The side pipes are the glasspack ones from Arizona mufflers. I changed them for the CR original about 8 years ago(or less-memory isn't what it used to be) because the CR's were too restrictive. I don't think there is much glass left in them because they are louder than when first put on. They are still on the car. I am in the process of making some new quieter ones (I hope) from TurboSpiralMufflers. The headers were also ceramic coated but they could probably be re-coated as there is a little rust around the edges. I will try to attached pics of everything.
Paul
life is short: eat dessert first !
