Jon,
No experience with Pro Comp but if you are going to run a points distributor I would suggest a dual points one. And if you are going to be running very high RPMs then I would go away from the points completely. On my stroker when I first had it built I ran a Mallory dual point racing one and had to change it out to a magnetic one because after a few runs, even with those expensive points, I would start to get point bounce which causes misfires at higher RPMs. After several talks with the Mallory Techs, they told me that the heat and cool cycles would make the points bounce at high RPM and that I needed to go to the magnetic one. I did and ran it for 7 years with no problems. There are others just as good and I am sure many people will be answering that have more experience with them than I do.
