IF you are hearing a squeal in the rear,,,,check it before yoy drive it again! It amy be something as simple a a loose nut to something more serious,,,if it fails at speed or on the road you could end up in serious trouble....I would check all U-Joints, Bearings, fluid level in housing, every nut&bolt that holds the Jag rear-end in place...
On the
oil, I have gone with Royal Purple (
synthetic) If I recall, it is 70w.
You could always call Unique and talk with Maurice or AL ,,,,they will definetly help you out
Jorgen Moller
Founder/Inventor
RaceDeck Garage Flooring
800-457-0174
All CC Members Get Discounts
[b]
http://www.racedeck.com
Life Member of the Bonneville 200 mph Club
05' Ford GT- Retune , Pulley & Exhaust 650+hp
Superformance GT40 MK2
63.5 Falcon Sprint ' Voodoo Falcon' GT350R powered
93 Ford Escort RS Cosworth FIA Rally Car
