Thread: Front Brakes
Old 10-14-2001, 07:02 PM
hford hford is offline
Thanks to all for the input!! In response to Jack21 -- I am using 15" wheels all around. The rear end is a 8.8 IRS Lincoln MkVlll type with discs. As for the front end, it has Mustang ll spindles as I stated. I like the looks of the Wilwood set up. It has aluminum hubs, the rotor (10.75) bolts to the back side of the hub, and the calipers are dual piston type. The thing that really concerns me for street use is the fact that this Wilwood setup uses a solid (non-vented) rotor. Rotor appears to be approx. 1/4" to 5/16" inch thick. Any input out there on using non-vented rotors on front of street car? Thanks again snakers!!!!
