Thread: Front Brakes
Old 10-14-2001, 07:10 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Thumbs up
Ditto on the Performance Friction pads. They are excellent, and available @ Autozone (mine were 27.89). I use Lincoln Mk VI brakes front and rear w/ rotors redrilled to the 5 on 4.5 bolt pattern. My car has the solid axle 9" rear, narrowed 8.25" by Currie (came from a Mk VI), so I used the stock disc setup but had to weld on spring perches and a new bracket to use the 4 piston discs from a 99 F250. Very big, very heavy and stop VERY well!! On the front I use the M2 spindle, Lincoln Rotors and the 4 piston calipers from a late model F150, again w/ a homemade braket cut from 1/4" plate steel. Absolutely excellent stopping power from any insane speed. I can give you part numbers if you like, and all parts (except the mounting brackets) are available.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
