Old 09-19-2008, 04:00 PM
olddog olddog is offline
Originally Posted by Barnsnake View Post
The gears are in constant mesh, so you're not changing tooth combinations when you go in and out of gear. You might have a problem with a shift collar, shifter fork, or bearing.
Are you positive? If the teeth of every gear is alway in mesh, then they must be locking and unlocking down at the shaft as they slide in and out. I thought the shifting forks slide the gears up and down the shaft and take the teeth in or out of mesh. In nuetral no teeth would be meshed. If I am wrong, please explaing this to me. It's been 28 years since I saw a manual appart.
I was playing with it today. I can go to neutral and back into 4th and feel a different intensity of the vibration most times. I have also found that majic no vibration spot at will many times. It may take 4 or 5 attempts, but I can find it every time I try.
With 4th being the only 1:1 ratio (having the same number of teeth on both gears), it would be the only gear that, once meshed, the same teeth would alway touch each other.
