Old 09-20-2008, 07:26 AM
mikey mikey is offline
Default EFI/Header question
Hi guys
I have a Dax over the pond 415cu in Motown Chevy with Dax exhaust where the headers slide into the 4 branch of the side pipes. I have bungs already fitted in the collector area where the 4 merge into 1.
Has anybody had any issues with the sealing of the sidepipes in an EFI siuation or does the paste do a reasonable job.
Any advice would be appreciated as its an area I know little about.
The system I will be getting is TWM Throttle 50mm bodies with an Accel Thruster management system. Whats your opinion on this set up if anybody is running it. I have always had problems with my BG 850 annular discharge (crower 00427 cam) even though I have capability and have tuned the air bleeds etc etc not just the mixture screws.
Also can you use the MSD 6AL with this set up as I have one already fitted.
Thanks in anticipation.
(sort of smiling third day of sunshine this year - groan)
Mike
Mikey B
