Old 10-15-2001, 04:56 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Exclamation
BP's line is correct--but be careful power bleeding at all, as you can damage some of the residual valves in the system if they are present. Why not liquid bleed the system and be safer? Just need a clear, clean bottle, some vacuum line and some brake fluid. Hang the bottle somewhere about 1/4 full of brake fluid, attach the vacuum line over the bleeder screw and into the bottle UNDER the level of the fluid. Pump the brakes 3-4 times, close the bleeder screw and remove the vacuum line. Than follow the normal bleeding sequence. One man brake bleeding, almost fool proof!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
