Thread: tire pressure?
Old 09-24-2008, 02:47 PM
McD00's Avatar
McD00 McD00 is offline
Cobra Make, Engine: 931 mangled in parkinglot incident - traded for new house roof <sob>
Originally Posted by Silverback51 View Post
Up to a point that is true. However, if you run more negative camber, it will not work.
I personally run 3/4 degree negative camber so it corners better. The spec calls for 1/4 degree for street, and 1/2 to 3/4 for competition. I pay for that in tire wear, but figure it's worth the trade off.
Then you average. For example from outside to in....109-114-119 degrees would be perfect for running more negative camber. Now if the temp was 109-125-119 then I would drop 1 psi at a time until I get a nice average. If the temp was 109-100-119 I go up just 1/2 psi at a time until I get that nice average. Just remember with more negative camber the inside will always be the hottest.
McVette
"...Just Shut the phuque up and Move on please..."
