Thread: Project Echis
Old 09-25-2008, 09:53 AM
MChat MChat is offline
Cobra Make, Engine: Sage Brush Roadsters body, Custom Chassis, SRT-4 Engine
Default Project Echis
So after getting my old car (Dodge Neon SRT-4) back on the road, she's officially "kicked out" of the Garage to make room for Project Echis.
Echis is the Greek word for Viper, it is also the family name of some of the most deadly snakes in the world (in particular: Saw Scaled Viper & Carpet Viper).
Current Plan:
Built 2.4L Engine (from SRT-4)
GT3576R Turbo
Tubular Turbo Manifold
Water to Air Aftercooler
Clutchmaster Twin Disc FX650 (1 FX700 disc and 1 FX600 disc)
Quicktime Performance SFI certified Bellhousing
Stock ECU w/ SCT Flash (bigger injectors, 3 bar MAP, ~7500rpm rev limit)
AEM FIC controller to control 2nd set of injectors*
MSD DIS-2 Programmable (better ignition managment + 2 step & anti-lag)
Ron Davis Racing Radiator
Tubular Chassis
Mustang II based front suspension (probably from Art Morrison)
Triangulated 4 link rear suspension (probably from Art Morrison)
Ford 9" Rear
- 35 spline 1.5" axles (possibly gun drilled)
- ARB Air locker (open diff for the street, spool for the track)
- 3.73 ~ 4.11 gears (haven't decided yet)
That's the basics.
*Note on the 2nd set of injectors:
The idea is to run stock or Stage 2 injectors from the stock ECU pumping in 91 oct pump gas.
The 2nd set of injectors will be controlled by the AEM FIC and pump in straight Methanol.
Between the higher "octane" rating of Methanol and it's cooling effect, I should be able to run race-gas like boost on "pump gas."
I'm also considering E85/Ethanol or E85/Methanol as an alternative to PumpGas/Methanol.
On to the pictures:
