Since 60-70% of the braking is accomplished with the fronts, I would certainly go there first. Consider the proportioning valve if you're going to mix systems. You don't want to create a situation where you can't get the right balance. I would also recommend that you call Wilwood and tell them what you want to do and get their expert adivce on the mix of systems. They are good folks and they are the experts not me.
Rob
