You have the wrong clutch for powershifting
PSERRA P, If you don't give that clutch enought clearance between the floater and the discs, it will drag. This is not a good speed shifting clutch. It's for holding onto large motors with 600+ HP and Torque. TOO much moving mass also. You should have gone with a multi disc like a tilton 2 or 3 disc setup like 8". You keep banging gears in that trans and you will also bend the forks, wear out the fork guards, break blockers, and or round synco's. IMO you should have gone with a super street richmond 5 spd. It will take the same abuse, has less shafts inside and again IMO a better designed trans. Gears are cut at a lesser angle to handle more load. If you want to keep power shifting go to a single 11" disc setup. Stay away from centerforce clutches. At high rpms they cause the same problem. I know it cost me $5,500.00 dollars to find this out after many phone calls to there tech department. Rick L.
