  #8984 (permalink)
Old 09-28-2008, 08:38 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by trularin View Post
Well I don't remember saying this...but the lift is broken again. The seal on the OTHER side went. I suppose I will fix that next spring.
You just fixed that this spring. What, you only replaced one o-ring, not both sides?
Whatever you do, do not do what a friend of mine did. He lives about 1/4 mile away and just had a hydraulic lift installed in his garage.
He went and checked the fluid after he had used it a couple of times, and it was really low, so he added fluid. But he did it with the lift in the UP position.
When the lift came down, fluid squirted everywhere around the garage. It took him about 4 hours to clean everything up.
Warren
