IWC, attach the rotor and it will become clear. It is keyed to only go on in the correct orientation. The electrical contact of the rotor should be co-located with the #1 wire in the cap. Then you will only be off by 14 deg or so - the BTDC advance.
If it is off, pull the distrubutor out and reposition the rotor shaft. Note that the slant on the drive gear will cause a 20 deg or so rotation as you shove the distributor in, so you have to allow for that.
Sam
