Old 09-30-2008, 04:53 AM
Double Venom's Avatar
Double Venom Double Venom is offline
KCMCHRIS,
I've been building these since prior to 97' I have neveer seen one without the frame mounts that eddie is showing, granted his motor mounts are the new ones but the actual frame member should be welded in. Now assuming they are not (?) then you are starting from absolutely scratch and assuming you have the mounts you are planning to use at the right height, right angles and the right locations for left and right is going to be a big maybe! I have done what you are doing a hundred times with street rods as they don't come with any type mount location. If you want get a paper, pencil, tape measure and call me I will take all the time you need to locate the mounts you are using correctly.
DV
1 231 869-4608 please call from 9AM to 5PM est to make sure I am in the shop
