Old 09-30-2008, 05:01 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hey Street,
I like to wrap a couple of coils around a 1" deep socket for a clean looking vibration dampener. I think the washers you mentioned are the compression Ferrel's. Teflon tape IF applied properly is OK but may I suggest Aviation #3 sealant or even a small amount of black RTV. Only apply sealant material to the last 1/2 of the threads so there is metal to metal contact if installing a electric sender so it has continuity or is grounded well. As a rule I do not use anything on brass into the block because the brass is soft enough to seal well without a sealer.
Teflon tape applied incorrectly can be a huge problem. The fittings for the oil pressure gauge is fairly small and most folks only have 1/2" wide Teflon tape although 1/4 " wide is available. The first full thread on the fitting should not be covered with tape, it should be wrapped with 3 full revolutions and in the same direction of threads when tighten. All this is so the tape does not get into the oil system or whatever you are working on.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
