Working hard trying to get done before winter. Got alot done this week. Windshield is in. Ran the alternator wire to the cut off switch. Got the Holley 800dp figured out.
Here are some rear firewall pictures. I found a metal supermarket. They had .060 diamond plate. I thought it might look good on the rear fire wall. Here some pictures. The hole in the middle bottom is for the electric cut off switch.
The stain from the right bezel is dust from the fiberglass. I can't believe how much a digital camera picks up!
Also test fitted the hood the air cleaner clears no problem. A performer rpm knock off intake with a edelbrock aircleaner.
I found a nice overflow for the radiator at pull a part from a kia for 3 bucks. It fits in the frame nicely.
