Old 10-02-2008, 07:19 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
The answer is Yes! I have a dry sump FE. The system is an old system used on some CAN-Am cars many years ago. I am in the process of changing my system because of the leaks from the two piece pan. My block is an aluminum Dove and can assure you that with a dry sump, you will not starve your engine while racing. I cannot believe a Pond block would be any different.
I am currently working with Bill Dailey at daileyengineering.com. Check out this guy's work. I just about have him convinced to build a billet pan with an integrated pump (no pan scavenge lines) for an FE. He builds a lot of pans for racers, but believes the FE is too old and not enough people are still interested in the FE.
I would encourage you to look at his site...the work is incredible. If anyone has an interest in a dry sump...contact Bill and let him know there are a lot of us FE guys who would buy this pan and pump. I need everyone to help convince him to build one for me.
Russ
