Old 10-03-2008, 08:48 AM
Barry_R Barry_R is offline
The oil that lubricates the pistons and cylinders is what is sprayed out of the crank. You would be amazed to see how much oil is flung off of a crank at high RPM. The stuff in the pan is not the real lube supply for the parts - its just the reservoir for the oil pump. Moving the reservoir outside of the block - dry sump - is simply a better way to keep it under control and away from the spinning bits.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
