with bell housing/clutch it will go
Guys,
My ERA 289 FIA 289 engine, a 289 block complete with bell-housing installed went in from the front of the car using the standard auto parts store "shop crane".
The bell housing/clutch was ALL installed. We attached a chain "sling" of sorts between the intake manifold lifting plate and the front of the cylinder heads...this allowed the engine to just about be vertical to go in...maybe a 60 degree angle...(lost all the photos with my f'n ZIP DRIVE).
There were three of us...one working the crane at the front...he was back and forth moving the headers up and down, watching to see the crane was not bumping the nose...(padded with card board and moving blankets).
The other was under the car using blocks and a floor jack to stop the block as it descended and then help rotate it back...I was running around checking everything and finally sitting in the car pulling the bell housing back as the floor jack moved the rear end of the block/bell housing up/back and the front of the block dropped down.
The firewall had a layer of cardboard box and padding but it wasn't really hit...do NOT leave it off or it will be hit.
OK, a juggling act, but with the crane dropping a controlled 1/2 inch at time no drama...
We did the same thing on my friends ERA 427 with 427 center oiler...bellhousing ON. BUT, we used a "dead fall" chain hoist...PERFECT!
The BEST situation is to find a garage where you can hang a "DEAD FALL CHAIN HOIST"...the engine will then go vertically up and down...NOT swing in an ARC as it will with the a "shop crane" where the boom scribes an arc as it goes up and down. On a rough asphalt driveway like mine the crane can be a bear to move because of the rough surface...do it on smooth cement if possible.
Pete
ERA 289 #2027
