turkey pan
hi bud!
my turkey pan was so tight with a 750 it was leaving black marks on the side of the pan i would say your turkey(carb) is just to fat! as far as leak check one way is at idle spray some carb cleaner around the base of the carb both in and underneath the t-pan if the idle increases it's drawing in the the cleaner indicating a leak my car had just gaskets, no sealant. hope this helps...
Ed
